last night my truck was acting up more than ever,only symptom was when you tromped on it then let off it would miss. did this again about a mile from home and at 70 let off and clutched again -this time it died(for good)with 13psi fuel pressure, maby this time it will be obvious enough for the dealer idiots!! I knew it wasn't worth taking back till it was DONE. Oh,by the way I coasted the truck all the way home up a slight grade around a turn and in the driveway-it stopped right in front of the house!! :-laf
the truck has had dead pedal a few times towing last summer,all this after the LP crapped a year ago before I had guages.
I now have DD2's and notice a lopey idle and wonder if this is normal ,or was part of my pump going with the 216 timing code?? any anwers???thanks guys,
Luke
02,HO,SB,QC,sport,white,285's,comp as EZ,DD2's,rips 4" straight piped,
Luke
