Leave 3 of the injection lines loose, at the cyl head. Prime the low side pressure system, then crank for 15 seconds... relax for at least 2 minutes, while the starter cools down, repeat 3-4 times, once you see fuel coming out of the three loose lines, tighten them up & she should fire up. May run rough for a bit, then should clear right up & run good.
