Engine/Transmission (1998.5 - 2002) vp-44 just quit -at idle...
Engine/Transmission (1998.5 - 2002) VP44-LP frustration
2nd Gen Non-Engine/Transmission Carfax
SSolderitch
I just put in a new fuel sender, drove maybe 75 miles, everything ok. I fixed the driveshaft yoke leak by tig welding the cap. Was planning on a ecm swap when the truck goes in for the anual state inspection, later this month (vin flash). So on sat. I ran some erans, clocked about 15 miles, made a quick stop, so I let it idle. I was standing not far from the truck and I heard the idle change - like missing a few cylinders. I got in the truck and stepped on the gas pedal and had no responce, fuel press still showed 15, but the idle did not raise - tach still showed 850 rpm. Then the fuel pressure showed 5 psi so I shut it off. I went back with a fuel filter and my smarty to pull codes. Smarty was not loaded due to bad ecm - hence change listed above. I got the following codes p0251, p0252, p1688, p0602 p1698, p1693 & p1694. I normaly get the p0602, p1693 & p1694. I just cleared the codes the day before. Yes I know the p1688 = pump replacement. I have the following questions:
Do the vp-44's go out without warning? This is my first failure
stock or hotrod? $500 adder... I like more power, but with the rv274, stock turbo, 4" exhaust and Smarty revo (soon to be loaded) Do I really need the HR? or will everything work that much better with the HR? NEED ADVICE.
I really don't want to hurt towing or durability for a ponys on the dyno. But I do like power (got my first speeding ticket two weeks ago, driving 37 years, in my truck. I learned to lighten my right foot). Is the extra $500 worth the actual hp I will get - bang for the buck.
today I also tapped the starter and the gauge showed 17 psi, I did not even bother with the fuel filter change, but the truck won't start.
I plan on doing the work myself to save some bucks.
Just like the rest of us, follow the troubleshooting procedure on the Blue Chip Diesel webpage.
Blue Chip Diesel Performance Specialists
Bottom line: If you have fuel, power, and ground it should start and run. If not, you need a VP44.
I would not invest in a hot rod pump. I think the hot rods are the next step for someone who already has massive fuel and air upgrades and is looking for more. I think another regular pump would be the right way to go.
I can't really speak from experience because i do not have a hot rod vp, but i think if you want more power, there are other ways to get more bang for your buck. The power increase will be minimal compared to what you could gain from a turbo and/or bigger sticks.
Obviously, opinions vary but I'm very happy with my II HR pump. It felt like a bigger set of sticks. Mine doesn't lope at all, I hear some do. It's a top quality pump but whether that's worth the extra $$'s is subjective.
