has anyone had or heard of a VP-44 pump making noise when failing?
i have my dads truck in the shop right know and it has a noise coming from the front of the engine. it also seams to have lost full control of its fueling when under full load, sometimes it has no power and sometimes it has way more than it should(i don't know if you could ever have too much but this is close)
Note: lift pump pressures are good 10psi at wot under load(40 ft trailer) Truck is a '01 eth with 275hp injectors, no other mods
Thank you for your help--Doug
