Since I recently had to replace my VP-44 due to too frequent P0216 failure codes - and since I had also taken GREAT care to always use lubricity fuel additives since the truck was new - I decided to take a gamble and have ONLY the defective parts replaced.
A bit of a gamble, since it could easily turn out that a partial rebuild MIGHT end up costing close to the same as a full rebuild - but since I'm curious, I was interested in seeing if possible, what exactly had failed in my pump, and to see if my fuel additives had helped at all.
I sent a request that all replaced parts be returned to me for inspection along with the fixed pump - here's what came back:
Essentially, all the internal rotating parts - plungers, rotating assembly and bearings were reused - as well as the PSG computer module - more on that later.
And of course, the outer case was replaced to upgrade the brass advance cylinder that has been a known premature wear/failure item.
Here's a shot down inside the VP case - some slight polishing where there was contact with internal components - but NO discernable wear anywhere.
Here below seems to be the most likely failure point - shown is the bore and pressed in brass sleeve for the VP-44 timing advance piston - at first inspection, it too seemed unworn - but carefully testing the bottom portion of the bore revealed a small wear area/ridge that *possibly* could cause erratic piston movement, and erratic fuel injection timing - and resulting error code. In any event, it's good to be rid of a known failure point!
I don't know that for a fact, and no supporting info was included with the pump and replaced parts, so I hafta make one of those hated WAG's (wild-Arsed Guesses!
Newer cases now have a hardened steel liner instead of brass as this one does.
The rest of the advance bore, and the piston itself appeared flawless.
Here's the top of the VP case, with the PSG module removed - the larger hollow to the left is the fuel reservoir where cooler incoming fuel contacts the PSG module to provide cooling. The smaller opening to the right is where incoming fuel flows to after leaving the PSG cooling chamber - at that point, the fuel is in direct contact with the pump's rotating assembly in the cavity below.
And finally, here is my biggest puzzle - the PSG on my pump was NOT replaced, I was told by their tech that it checked out fine, and was the latest available revision level, later even than the "Fedex" unit:
And what's puzzling about THAT, is that as far as *I* know, the most "recent revision level" was not even available until earlier THIS year - and my truck is a 2002!
The tech said there have been *3* PSG's - the original, the later so-called "Fedex" module - and finally, the one II and other Bosch rebuilders only recently started replacing the previous units with...
So what gives?
How could I possibly have the latest PSG module in my original '02 VP-44, if it wasn't even being manufactured/installed until earlier THIS year?
Someone's confused - is it just me?
SOOOoo - anyway, was my "test/experiment" a success?
I'm not real sure - I paid $950 for what was done instead of $1100 the full rebuilt/exchange would have been - but am still left with virtually ALL my old rotating/pumping assembly, as well as my original PSG. Was it worth the $150 savings? Well, If I knew then what I know now, I'd undoubtedly go ahead and pay the difference, and presumably get ALL new parts!
I had hoped that in addition to SOME savings, I'd also get a clear indication as to EXACTLY what was giving me error codes - but in fact, other than the advance bore wear noted earlier, there is NOTHING, no clear evidence or explanation as to what was actually wrong with my pump - and after all, that WAS one of my primary reasons for choosing to make the replacement as I did.
NONE of this post, or my comments should be considered as a complaint directed towards II- they are NOT! I took a gamble, calculated risk that I might learn a bit more about these pumps, and the effectiveness of my use of fuel additives - I guess they must have had SOME benefit, since II saw no need to replace the major moving parts of my pump - so I will continue with Power Service and 2-stroke oil...
MEANWHILE, if any Bosch guys reading this want to shed any light on the PSG issue - or any of the rest, your comments are welcome and invited.
So what gives?
