So for about a year now my truck will randomly not start after it has been started a few times during the day (running around town from place to place), it will usually start fine if its been sitting over night or all day while at work.
I'll have this problem for a couple of weeks or what not, then it will go away and be ok for a few months. It would do this when it was stock, no chip, just intake and exhaust. I've recently got the truck running with a new transmission, Jammer 3 tips, TST, and Superchip... . Now its starting to not start again...
When it doesn't want to start it will just turn over and not catch, as if there is air in the line. It throws no codes, checked with 3-key on method, Superchip, and Snap-On scanner. Blipping the key to get the LP running to "prime its self" doesn't work, no matter how many times you do it. The first time i posted this some one said maybe the lines are leaking. I've checked all the line, and there has never been a leak. I thought it was my fuel pressure line causing problem so i took that off for about 7 months and it would still do it.
What seems to work every time is jumping up, cracking #1,3,4 lines and crank ing it over for a second and then let it prime its self while i close the lines, that will usually do it. I spent almost an hour to day in a parking lot trying to prime the FREAKING LINES, and could barely get any fuel to come out of the 1 and 3 lines. I thought i wasn't primed up to the VP so i took my FP line off and blipped the key... bad idea, there was plenty of fuel there and i got the FP line back on while it was priming.
I would try to start it every which way, no throttle, half throttle, full throttle, rolling on the throttle.
My main question (after all this bs) is HOW IS AIR GETTING IN THE VP??
Is there anything else i can do beside just replacing the VP, fuel pressure is good.
WHAT IS LEFT??!!!!:{
