Check to be sure lp is putting out good pressure. Check your fuses/relays. Under the hood check the fuel system relay, that one will keep the truck from starting. If all are good crack 2-3 of the lines at the injectors and crank over to see if you are in fact getting good fuel flow to the injectors.
Dirk
