Engine/Transmission (1998.5 - 2002) VP44 Dead ! Yippie :(
Today ..... It happened ... P0216
Was returning home with my new fender flairs and truck lost power ..... then got it back and threw the CEL ,,, Limped it the whole 1/4 mile home and scanned it
Then made a few phone calls for moral Support
Then Limped it to ****** and set down with a cigar across the table from him and started talking bidness
Was Caught between
a 028-ip HR Vp44 and the ADD and keeping the bosios
and
a 027 Stock VP44 and the ADD and some "Special" Custom Injectors ... So special he wont even tell me anything but . . Custom Made 7 Hole 150-160 HP 380 CC Injectors
The HR Pump senerio is More $$$ and Less Performance
So Im going with the Injectors,027,ADD
This set up is suppose to smoke my Comp 5x5 , Bosios Set Up , and the HR Pump Senerio
DM
I understand that maliciously smoking innocent Jeep drivers frequently causes premature VP-44 failures, along with other nasty events - you ever done anything like that?
(inside joke... ) :-laf :-laf
I feel for ya DM! Bet hey look at the bright side, it's not like you dropped a valve seat into the cylinder! :D
It seems like there is a rash of VP deaths every spring. I wonder if the temp swing is causing the circuit boards to crack?
The Bosios Dont add much more Smoke or Power than stock They are an upgrade and a way Better route than the RV's (Quallity) but your best bet to to save up and get a complete injector thats proven
JMO
DM
