I have a decent garage/work area, and lots of good tools, and the job probably took me over half a day because I piddled around with extra cleaning in areas otherwise impossible to get to - I like to keep the engine and underhood as spotless as possible...
The part that probably caused me the greatest puzzlement, was getting that dern control cable/plug loose and disconnected - talk about a Chinese puzzle for the inexperienced! :-laf
BUT, got it after a good 5 minutes of pushing, pulling and head scratching.
My best advice is to early on totally remove that dern rear engine pulling fixture/loop off the intake manifold - save it just in case, but LEAVE it off the truck for easier access to the injector lines and fittings - you'll see what I mean when you start working back there. I used thick washers to make up for the thickness of the fixture, and used the same original bolts to properly hold down the manifold top plate.
I also removed the driver side battery for good unobstructed access to the VP-44 area. There are a couple of excellent photo articles on doing the swap - I used one of those for a general guide, and it was a great help - someone will undoubtedly post a pointer here for you.
Be sure, after the install, to leave all the lines loose at the injectors, then crank the engine over until you get fuel flow at each injector, then tighten them down. Once the engine fires up, recheck each line for leakage, and tighten more as needed - here's where you'll be glad you left off that engine hoisting fixture! :-laf
Good luck!
