Howdy,
I just installed a HotRod version VP44, the install went perfect and easy,
the problem is my idle speed is 950 RPM, is this normal or can I adjust the idle speed. The other problem is the engine seems to have a miss, it kinda sounds like a gas engine with a race cam. It lopes then stumbles about every 5 seconds or so, then lopes again, my engine is also much louder than before the new pump is this normal.
This thing has awsome power more than I had on level 3 with the Edge Comp connected, I did not connect the pump wire yet as I wanted to check out the driveabilty with out it first.
My fuel presures are a constant 15 psi.
Thanks, TJ
Thanks, TJ
