Archived VP44 Mounting Bracket Broke
Archived 2002 24v died under power. wont start HELP
Archived Pump timing help in Haines, Alaska
Started in this morning to replace the vacuum pump shaft seal because that's what I thought was causing a pretty heavy oil leak and found BAD NEWS! :eek: My VP44 mounting bracket was broken and I lost two of the four main mounting studs (from the timing cover assy) and all four of the nuts! I don't know what was holding the pump in?!
I guess I caught it just before seriously worse things started to happen, In any case, I have checked everything out and no cracks on the timing cover assy but a couple of the holes where the mounting studs were are slightly worn and may cause problems when I try to put the new studs in. Also one of the injector fuel line brackets was cracked, but should be easily replaced or fixed. Other than that, I don't think anything else suffered much damage.
I need to either replace the bracket that goes from the rear of the VP44 to the block or have it welded. Anyone have any recommendations? I also need the mounting studs. Any recomendations as to where I can locate these would be helpful. I didn't have any luck locating anything here locally today (Our dealer is closed until Monday. ) Any suggestions or other ideas would be much appreciated.
