Engine/Transmission (1998.5 - 2002) VP44 need help
2nd Gen Non-Engine/Transmission Axle Hub Seal
Yesterday I was running on the highway with a friend. He asks me what is that Edge box for with the small button?
Well I say if I turn it red look what happens, so I put the the power edge box to the red light and push it. Wow he goes this thing is scary and right after I got a dead pedal. I turn the key of, try to start it again but it will not run. the lift pump is running.
As I have a 99 I cannot read codes. The check gauges light stays on when I crank the engine.
VP44 dead, I am 99% shure
Any opinions?
Yep VP44 is dead.
I had a cracked 53 block with the pump and just swapped the pump, running fine now.
Any repair centers for VP44's? Might me a good time to upgrade!
Thanks,
Raf
Any opinions?
The older VP's are more subject to failier.
