As I interpret it the longer the fuel solenoid is held closed, the higher the probability there will be a high pressure spike in the middle of the rotor slot and flexing and galling and failure.
"The reason this happens is because the fuel solenoid is held closed longer, therefore using more length of the slot in the rotor. The slot in the rotor overlaps a hole in the distributor to allow for different timing and amounts of fuel to be delivered to the injector and when the solenoid holds the bypass solenoid closed longer, then the high “pop off” pressure is still there when the middle of the slot overlaps the hole. The middle of the slot is the weakest area and therefore deflects, interferes and seizes. "
But also clearly is the lubricity issue and the extreme close internal tolerance of the pump.
AND the durability of the circuit board.
AND the design of the pump in general.
AND, AND, AND the mentality (mine included) that because I xxx and my VP has not failed then I have the answer. I try to look at the fuel system as a SYSTEM rather than a lp pump (or FASS or RASP or XXXX), rather than banjos vs full flow fittings, rather than lubricity only, rather than prefiltered fuel with free water removed.
There is nothing I can do about the circuit board longevity. However, I can and do effect whatever I can, prefiltering, no free water, lp on frame, as close to exact feed pressure as I can (12 psi) with the bypass regulator, lubricity with Stanadyne, not tapping the pump wire so the fuel solenoid is not held closed so the "pop off " pressure is not a player (as much). Hopefully avoiding the galling with Stanadyne PF. And by dumb luck I have a 2002 (ie later model pump).
I change the things I can change, I do not change the things I can not change, and hopefully know the difference,
Bob Weis
