I thought i lost my glacier diesel walbro lift pump.
Fuel pressure dropped to 12 lbs, i changed the filter , it stayed the same. Next few days the pressure dropped to 10 then to 8 I ordered a new lp. I checked the bypass valve (inline by pump)to be sure it was not stuck open, it was fine. I also cleaned the pre filter (strainer) before the pump it was clean and clear.
Pressure ended up at 3 then 1 i parked the truck. Tonight the pump showed up and i installed it. Started the truck and no fuel pressure. I checked the electrical system working fine had 12. 4 volts to the pump. I restricted the bypass and got it up to 5 lbs on gauge. I was thinking air in the lines but truck ran fine. I have a mechanical pressure gauge with vulcan isolator, i bled it and still 5 lbs.
My question is, the bypass in the vp44, could it be stuck open? I ran out of time tonight to look how much fuel is being returned.
I have a drawstraw and 1/2 inch lines from the 392 lp (frame mounted beside the tank) to a 2002 fuel filter and all the way to the vp.
Any ideas ?
Dirk
Any ideas ?
Dirk
