I am installing an aux bed tank.
I have my VP44 return line plumbed into the OEM tank vent line up high almost to the bend where the vent line attaches to the OEM tank filler line.
I plumbed my aux bed tank to gravity feed the OEM tank through the alternate DrawStraw port (right to the top of where the cannister screws down to the tank body)
What I found:
When the aux had fully filled the OEM tank and the engine was at idle (only) the VP44 threw a 0602 code. Would not throw the 0602 if any above idle.
I stopped the aux feeding the OEM and burned down several gallons. Reset the 0602. No more 0602 codes at any rpm.
I returned the aux to feeding the OEM and let the OEM get fully full. VP44 threw 0602 at idle. Same scenario as above.
Stopped the aux feeding the OEM and burned down several gallons. Reset the 0602. No more 0602 codes at any rpm.
Got home took the VP44 return line from the tank vent line and plumbed it into the aux bed tank vent line. No codes. Yes you have to leave the aux tank filling the OEM because the VP44 is returning OEM fuel to the aux bed tank and it would overflow.
What I think happened:
At rpm's above idle the VP44 body bypass valve pressure could over come the pressure in the tank vent line. At idle the VP44 bypass valve pressure could not overcome the pressure (air pressure or fuel weight pressure) in the OEM tank vent line.
Side benefits of the VP44 return line into the aux bed tank.
The aux bed tank acts as a passive fuel cooler worth about 5* of fuel cooling.
You can literally see the VP44 return fuel flow by taking the aux tank fuel cap off and looking at it VP44 return fuel stream.
You can pump the OEM tank out to a reasonably low level (not dry) by stopping the aux tank flow from the aux tank to the OEM tank and letting the VP44 pump fuel from the OEM tank to the aux bed tank for you.
Just something I found out, thought it might help someone
Bob Weis
What I found:
Bob Weis
