Ok I bought my first 24 valve, a 2001. 5 with 70,000 miles. Installed gauges and an edge ez. Fuel pressure was around 10. 5 and I could pull pressure down easily under throttle to around 5 and 6 pounds. I decided to get the vulcan big line kit, and a new lift pump from cummins. Received new lift pump 4090046 and installed with vulcan big line kit. Now fuel pressure was at 9 psi and it barely lowers under heavy acceleration. I don't even lose a half pound. Thought the pressure would be higher with new lift pump. Talked with cummins dealer here in Lincoln NE and he said he will get me new lift pump. Removed new lift pump and put original back on with vulcan kit. Again 10. 5 psi, but would pull down to about 8 even with big line kit. Got new cummins lift pump again with same part number 4090046 and still have 9 psi and it doesn't hardley change under acceleration. Does anyone know if the new lift pumps from cummins run a lower pressure. I seem to have decent pressure and no drop under throttle. I called cummins and they told me to make sure I have over 5 at vp44 and bosch says 7. I have my gauge hooked up to the port in between the fuel filter and vp44 supplied in the vulcan kit. I feel the new lift pump is very stong compared to my stock lift pump that will pull down under throttle. Is there something I am missing, or is my pressure ok. Eric with Vulcan has been great to deal with (as well as my local cummins dealer)and the kit was easy to install.
