Engine/Transmission (1998.5 - 2002) Vulcan Big Line Kit
2nd Gen Non-Engine/Transmission speedo Cal.
Engine/Transmission (1998.5 - 2002) help with lift pump install
It comes directly from vulcan it comes with 1/2" fittings for the filter and pump a t for the gage 1/2 line and 3/8 line from out of the tank it comes with a 3/8s fitting and 1/2 fitting for the pump and a pig tail lead to move the pump to the frame along with a pump bracket. I bought the stainless fittings, wich came with non stainless hose clamps :( I tried to find his address, I no longer have it book marked. he is on ebay do a search for dodge lift pump, and you will see all his kits.
I installed the Vulcan SS LP Relocation kit a month ago. It ROCKS! The 1/2" fittings are flawless, the clamps are not SS, but they are smooth bands instead of slotted bands, so they don't cut into the hose. With a stock pump next to the tank, no pusher, I run 15+ psi at idle, cruise at 13+ and WOT never drops below 11! I could suck it down to 5psi before. By far the best $100. I have invested in my truck. The customer service matches the product too.
I'm getting great results here also... 15psi gauge buried at idle... 13. 5 at 70mph and can't get it to go below 12. 5 WOT. I'm a rookie with minimal tools and it only took me 90mins from popin' the hood to test drive! I put in the anodized kit cause it has the 1/8 tap and the snubber went right in. Eric has about a dozen of them left as of last week and he's marked them down and I can't say enough about the service. I called to order and he happened to be coming to this way the next morning and brought the kit to me. Now with the pump where I can reach it, replacement will be as easy as 2 line clamps and 2 wrenches and the new pump which I carry in the truck. Hell, I can do that on the way to church and not get dirty(oh, I forgot to mention the coveralls)!
