Preparing to upgrade to the mechanical fuel sender as rweis describes here. https://www.turbodieselregister.com/forums/2nd-generation-ram-forum-no-engine-transmission-discussions/179541-fuel-tank-float-how-many-us-had-change-because-deteriorated.html I now have the parts in hand. As far as the Draw Straw goes, the kit comes with an 18" length of 5/16" fuel line for the return from the VP-44 into the thak. From what I can see with the tank still in place, the return line is steel along the frame and then somewhere beside the tank transitions into the flex plastic line that goes into the factory quick lock connector to dump into the top of the fuel module. The Vulcan kit comes with a 5/16" pushlock to 1/4" NPT fitting, should I have any other fittings on hand when I drop the tank? Or will the steel line just have a flare on the end that the hose will slip over and be secured with a hose clamp? (a hose clamp was also included in the kit) I already have 1/2" lines in place for the feed going to the AirDog, so that part is taken care of.
