Check your TPS, I've had problems where it wouldn't shift into OD and I've had problems where you may be cruising down the highway and all the sudden you are in third gear. It was the TPS.
92 2500 Reg. Cab LE
Dark Spectrum Blue and Silver 4x4 Auto
PW Injectors, 238,000 miles, 16cm2 housing,
Isspro guages, DTT torque converter 91%,
modified vb, new 518 trans, Mag Hytec
transmission pan, second gen gear
shift lever with OD button.
