I just did a rear brake job on my 1990 w350. I didn't like the nylock/wedge bearing retainers, so I replace them with the two nuts and locking washer with the tabs. (like ford used to use). But I wasn't sure on the adjusting proceedure.
Can someone tell me what the correct proceedure should be?
Would it be the same as the nylock? Tighten to 120 ft lbs. Then back off 120 degrees?
Thanks Mark
Thanks Mark
