On a Pro start, all three yellows are turned on together. . 400 seconds later, the green is lit. The idea of this was to decrease red lights, particlularly with vehicles that launch hard.
On a Sportsman tree, the yellows are turned on one at a time, at . 500 second intervals, as is the green, . 500 seconds later. This system remains in place for most sportsman categories, and is useful in handicapped racing, where some anticipation is part of the fun, and can provide a starting line advantage when exploited to the fullest.
The prestage light simply warns the driver that he is approaching the stage light beam.
The stage light on the tree is illuminated when the front tire rolls into and breaks the stage light beam.
This is very important! Elapsed timing (E/T) begins when the front tire LEAVES THE STAGING LIGHT BEAM, and ends when the tire cuts the beam at the end of the 1/4 mile. NO timing is taken from the green light. A CLEAR TO GO signal is all it is. You can sit in the stage beam all day with the green bulb a-glowing, and the only timer that will be counting will be the reaction timer, which stops when you leave the stage light beam.
Reaction time is the length of time between when the last yellow is turned on by the electronic timers, and when the front tire leaves the stage beam.
A vehicle can accelerate forward (approximately 12 to 18" with a normal tire) before the green light is turned on, with the front tire still breaking the stage beam. This distance is the tire's rollout, as in, rolling out of the beam. Most vehicles take several 10ths of a second to roll out of the stage beam. It's possible to use those 10ths of a second to accelerate the vehicle while the last yellow is lit. If the green light is turned on just before the vehicle leaves the stage beam, then
. If the vehicle leaves the stage beam before the green light is turned on, then
In other words, a red light is the result of accelerating forward enough to allow the stage beam to be detected by its sensor before the green light is turned on, . 500 seconds after the last yellow. It's a bad thing. A . 499 R/T gives you the red bulb. A . 500 R/T is a very good thing.
The third light beam is, I believe, strictly a guard beam to prevent 'deep staging'. I've never played with that, so I don't know much about it, except that the third beam is not involved in any timing function.
Because the bulbs used on the tree are incandescent flood lights, there is also latency in the way they illuminate when turned on.
All this means is that the green light must be anticipated.
Practice, practice, practice. A . 500 R/T is a beauty to behold.
Don't wait for the green! Or... . You snooze, you lose!
