Want good mileage?
ISS Pro gauges
Dealer messed up order but has an offer, need advice
Funny how this works. I usually get 19MPG around town. I moved the AFC forward and boy was that great and then I noticed, oh no 13MPG. Can moving the AFC hurt the mileage? Well I thought just maybe it might be my big foot so I took it easy for 200 miles, Bingo 22. 5 Mpg. Never let it get above 2000 RPM and boy does it get good mileage (but not near as much fun, oh well)
John
96 SLT C\C 2wd 5spd 3. 54 straight pipe. Bed liner,Twin Aluminum tool boxes, 45 gal bed mounted aux tank. Member
USPSA\NRA
what's the AFC and how do I find and move it?
BLACK BEAST: 2K1 QC, SWB, Auto, 4X4, 4. 10 LSD, SLT, Black, Camel leather, Tow pckg, nv241HD, cab lights, 2 inch daystar coil spacers, 35 inch Mickey thompson claws, bushwacker flares, rhino lined bed and rocker panels.
soon to come; DD stage 1's, boost module, possibly van aaken.
GREEN MACHINE: 93 Jeep Wrangler 4. 0L, T-18, 38X11 Boggers, Dana 44's, AtlasII T-case, ARB's, warn and moser shafts, Ramsey 5K winch... . NEEDS A DIESEL!!!!!!
Turbo-D, DEEZUL has a 96 Ram. AFC is For the Boost signal to the Fuel pump(P7100). For Turbo Lag and or smoke conrol?. . I cant Think, I have too Many Valves on the Brain!
Doug.
1998. 5,2500,ISB,Auto,CC,4x4,White Sport,275hp Injectors,240hp to the Ground,BD Pressure Lock,16x8 Eagles,295 BFG's,2. 5" Skyjacker Lift,Stockland Seibring Shell.
26ft Weekend Warrior.
1973 R/S Z28 Camaro.
1989 Jeep Cherokee.
427ci 585hp L88 Crate Motor, Still in the Crate!.
Tyrbo D
The AFC is on the back of the injector pump on top, it has 4 bolts holding it on and 1 of those is a break off bolt that is a PITA to get out (unless someone has been in there B4) loosen bolts and slide it towards the front of the truck. It controls fueling at different engine speeds and will make it smoke more at low RPM but runs stronger at low RPM also ( I love it). I dont believe the 24 valve motors have this setup.
John
USPSA\NRA
On Monday I did the 1st milage check since bombing. A good solid 20mpg #ad
and I'd been in it a little bit here and there #ad
95 2500 SLT Laramie 3. 54, automatic,Herculiner bed liner, JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N, AFC adjusted, dual straight exhaust out of "gutless" cat, Geno's dual EGT/boost gauge, TST #6 plate slid all the way forward, AFC housing slid all the way forward, silencer ring removed
"Layin' the 'SMOKEDOWN' on their ROOdy Poo CANDY GASSERS!"
