Hey guys I'm needing to level my truck to clear my 35s so they don't keep rubbing on bottom pushed out box part of my fender flares. Anywat I want to level it right and retain factory or BETTER ride quality while not having to spend $1,000+ for just a level. I've measured my ride height and the front is exactly 2.5" lower than the rear.
This now brings me to my question. Spacers or coils and why. Remember I want to fully retain stock ride quality or better. I do NOT want the ride to be any stiffer then stock.
I've found a couple different leveling kits on ebay as I was browsing through. Here's a link to each.
2.5" spacer kit with 5100s and sway bar relocater brackets
http://m.ebay.com/itm/2-5-DODGE-RAM...Front-Shock-/261971409809?nav=WATCHING_ACTIVE
2-2.5" progressive coil spring kit with set of 4 5100s
http://m.ebay.com/itm/2-2-5-LEVELIN...00-3500-4WD-/151725837455?nav=WATCHING_ACTIVE
Which of these 2 kits would be the winner and why. Also, if you guys have any other better leveling kit options thay aren't $1,000+ please post them up and link the kits to me.
Lastly on a 4th gen truck will. 2.5" kit require longer control arms and an adjustable track bar to re center the axle both fwd/rwd and side to side or do these trucks take easier to levels than my old 01 did.
Please let me know guys. Learning as I go on these 4th gens. Here's a pic of mine as it sits currently.
http://rsmg.pbsrc.com/albums/v224/C...15-07/20150704_180103_zpsruvufkim.jpg~320x480
http://rsmg.pbsrc.com/albums/v224/C...15-06/20150615_181214_zpsfwkyerbg.jpg~320x480
