You didn't mention why you needed this info, so I'll add this.
A common problem is that the brake lights won't go off until you pull up real hard on the brake pedal. Of course, while the brake lights are on you can't activate the cruise control.
The cause of this is that the brake pedal has been pulled up too hard in the past. The cure is to take the switch off, pull the plunger all the way out, and then adjust it as per the shop manual. The plunger has a ratchet gizmo so it holds the correct adjustment position ... when the pedal is pulled up too hard, the plunger stays pushed in and the brake light stays on.
In my case, I had to take the brake light switch apart in order to pull the plunger out.
Doing this saves the cost of a new brake light switch.
