Details here: TDR Privileges
What is the proper way to start and warm up the Cummins? Is it warm it to 140 and then drive easy until operating temps are reached or should I let it idle until operating temps are reached?
You will sit for a long time if you wait for those temp. numbers. Most people on here including myself let it run for a min. or two in neutral, make sure your oil press. up and then drive away slowly. It warms a lot faster driveing than setting idling.
These things will NOT warm up idleing. Since there is a lot of wear running a cold engine you want it to warm up quickly. So, like Diesel Freak says, when you have oil pressure leave. Just take it easy until you have some temp.
