Warning chimes, no codes, no message!
Underhood insulation
A/C blowing cold on driver side and warm on passenger side
rfitzgarrald
Recently I've been getting 2 warning chimes after I start the truck. 2007.5 mega-cab srw. It only does it when I first start it up in the morning. I drive it maybe every other day and my dashcam is always on. I have no message in the overhead display, nor an engine diagnostic code.
Anyone have any ideas what it means? Low batteries maybe?
Thanks in advance.
Did you happen to notice if the gauge cluster wakes up immediately when you start the truck as normal or is there a slight delay in the gauges? I had the same thing happen a few years ago and the chime was associated with the gauge cluster not responding immediately when the truck was started.
It ended up being a corroded ground wire of all things but it took me forever to track it down.
I'll have to pay attention to that the next time I start the truck either later today or tomorrow morning. Thanks.
I'd have to agree that it might be time for batteries. Get them load tested and maybe a good trickle charger for those in between driving times. Funny how these trucks give you subtle hints that it's about to leave you stranded! Was just checking my maintenance log book on if anything else needs to be done before it gets cold! o_O
I had the same issue as Ozy. I bulb was on its way out and took a month to finally fail. It would chime a few times every time I operated it.
I have heard a bad twilight circuit board will also cause this issue.
Good luck.
