Warranty Advice?
Black fuel filter?
Tires
Can any of you members help me out? My o7. 5 Chassis Cab is just about out of warranty. Are there any known problems that I should look for and have repaired under warranty?
The only things that I have had done at the dealer were a rattling speaker fix, and a heat shield issue on the 6. 7 Cummins. Also, updates on the computer worsened MPG. So far no codes on overhead display and 35,000 trouble free miles.
I am thinking of a complete DPF kit to improve MPG as I get only 8. 5 towing and 11. 6 empty.
Also, I have heard from a few '07 4x4 pick-upowners with failed front ball joints and front u-joints. I don't known if my Chassis Cab might have these failures?
Thank you fro any advice you can give me.
Dennis
_______________________________________________________________
07. 5 3500 Chassis Cab 4x4, 6. 7 Aisen auto. 410 gears, Bradford stake bed, ranch hand bumper. 35,000 miles
My 07. 5 2500 had new ball joint, one cartridge wheel bearing, and new tie rod ends at 80k. I think our front ends are the same, I would check those.
