Warranty Almost Up
Cold Weather Operation - Alaska
Warmup time?
I am approaching the end of my full warranty and need to make a trip to the dealer to get the doors adjusted to reduce some wind noise. I figure I will have them test the fuel pressure and make sure the lift pump is up to par. Is there anything else I should have them check out? 32000+ miles and no major problems yet other than the cheap paint(rock chips) and minor wind noise. TIA
Matt
in order to force them to check the liftpump you need to have "key words" on your work order, things like "low power" and maybe "hard start" in 98 I think it was low power, but that may have changed. once they plug in there test equipment you will get a reflash if there is one avalable, this can be good or bad, ask what the other 2001 owners have found
:D
Matt
I used the words "dead lift pump" since mine was dead. But I did end up with a new lift pump and a reflash. The new lift pump was good. But I can't tell if the reflash was good or bad :confused:
