2nd Gen Non-Engine/Transmission Washer fluid bottle removal?
2nd Gen Non-Engine/Transmission Transfer case rebuild
2nd Gen Non-Engine/Transmission HVAC vents
I've searched and I cant find the answer. Whats the trick to removing the washer fluid bottle from my 99? I've pulled yanked tugged and still cant get it out. Is there a screw or bolt Im missing?
Thanks
Craig
Look beside the fan on the back side of the bottle. You'll see a couple of tits on the bottle that stick through the shroud. Put a big screwdriver between the bottle and shroud to pry it away a little so they clear the holes and pull up on the bottle.
Bud
Also, contrary to what the service manual says, the upper radiator hose does not have to be removed to get it out.
