Washing the motor
connector at pre-heater filter harness
EXHAUST
Nope, wont hurt anything. Many use diluted SimpleGreen. I've done it. If you have a BD exhaust brake, be sure to cover the 'sinter' on the vacuum control module before applying any wet stuff.
[This message has been edited by Rattlin (edited 04-08-2001). ]
Simple Green is the way to do it.
I wait unitl the truck is cool, wet it down lightly, and spray on the Simple Green and let is sit for a few minutes. I'm careful to not get too close to any electrical connectors. Then spray it off. The results are excellent for ver little effort.
Ryan
Any problem with using "GUNK engine brite"? i get it from work, seems to be ok on most cars, any bad things about it?
No problems washing engine. Just be sure to cover the filter minder on the air filter cover. It will cloud up if any cleaners get on it.
1998-1/2 2500 Quad Cab, ISB, Auto, 3. 54 LSD, LWB, RBW 15K 5th wheel hitch, Rhino Liner, US Gear Dual Range underdrive,Weston Smirf bars, Bilstein shocks, AMSOIL bypass filer, synthetic engine oil and differential lube, Mag Hytec diff cover, Turbo Diesel Life Saver, Trans. temp guage, Boost & EGT dual guage, Stone Guard headlight protectors, 5" monster chrome exhaust tip, Better Built diamond plate tool box & bed rail covers, louvered 5th wheel tail gate, custom cummins stainless steel rocker panels.
1998 Alfa Double Slide 5th Wheel RV - See Readers Rigs page 6 for pictures.
