Wasn't a PE-EZ fault...I'm
96 4x4 Front Stabilizer Bar???
Anyone know where the coolent temp sensor goes?
EMBARRASSED! #ad
After getting back this weekend from NY, I went out and bought fuel filters. Drained out a bunch of gunk. Botttom of filter bowl was full of a gelitin substance and filter was quite dirty. Only 6000 miles on truck.
Also checked the fuel presure from the lift pump and it was in specs if my cheapy gauge is any good.
Took truck on business trip last night with HEAVY headwinds/crosswinds both directions and running 67mph I still pulled 17mpg.
Hooked up to the 5ver this AM for the ultimate test and I no longer have the miss/stumble/bucking I had last weekend.
The only thing I don't like about this set-up is how noisy it makes the engine! #ad
Heading for the UP this afternoon and will see what fuel mileage is MT with the EZ installed again.
Aaron of Power Edge, thanks for your assistance. Tried calling you several times today with luck getting thru.
"01" Forest Green QC/LB ETH/DEE,4x4, 3. 54LSD, VDO (boost, pyro) Westin SS Nerf Bars and Grill Gaurd, Delta tool box, K&N.
00 28' Jayco 5th Wheel, 86 "Classic 16" Alumacraft, 00 Honda Rancher
Towing with a slight "edge" on the competition!
Hope you had a good time in New York. I'm glad every thing is working alright. I just purchased a PE EZ will install tomarow. I will get those maps for you, I didn't forget. Will you be in Laramie in July? I hope to see you there.
Keith
2001 SLT ETH/DEE swb 4x4 3. 54 Forest Green w/silver. Century Cap
