Engine/Transmission (1994 - 1998) Waste Gate changes
Engine/Transmission (1998.5 - 2002) Surging trany
Engine/Transmission (1994 - 1998) Turbo mix-n-match
I was looking at some posts to see what I should and could do with the WG. I just recently installed a #10 plate and 3kgsk and I'm totally pleased with the change. Not much smoke and a lot more power range than before. The instructions I used called for the removal of the barbed fitting and the Tee at the back of the pump but I didn't have the parts needed to do that so ended up putting it back on. What shoud I do?
If you have a boost gauge, disconnect the rubber hose at the WG and plug it with a bolt. Works WAY better, just keep the pressure in check. I normally don't break 30 psi unless I mash it to the floor.
