Welded 12 installed....
Hey Jason & RB!
I installed my
"experimental" welded 12cm2 over the weekend & will evaluate this week during normal driving.
I understand the purpose of the wastegate on the 12 & 14 housings & agree with the theories mentioned above & before. This is an activity to satisfy my own curiosity and not suck anyone else into my opinions. I've swapped the 12 & 14 back & forth several times now on my truck & the other First Gen has always had a 16cm2. So, I've got to play w/ all of them on almost identically prepared trucks...
Here's what I've found:
The "Welded 12" doesn't behave much differently than the wastegated 12 on my/our truck(s) (my opinion & experience). Yes, I does seem to loose a bit on the top end & I find this loss to be in line with what the wastegated 12 exhibited. The low end & mid-range reponsiveness is impressive though & the EGT are up maybe 100 degrees... Same as wastegated 12. The Boost differences between the welded & wastegated 12 are exactly the same to my disappointment. I'm getting 28# in 4th & 30# in 5th... Same/Same! I was getting a max of 26# w/ the 14cm2 I just took off when the wastegate opened (for reference).
Much of this was done to prove to myself that w/ the limited fueling of the Bosch VE44 on our First Gens that a wastegate isn't as necessary as on potentially over fueled P7100 & VP44 brothers. Remember D/C is putting 9cm2 & 10cm2 on the newer 24 valved trucks that have incredible fueling capacity over our trucks. I'm a bit disappointed that the
"Tale of two 12's" has such a identical ending to the story!
I plan to drive this housing for a few weeks and evaluate... In the end I might just put the 14cm2 back on my truck and leave it! The only remaining question would be to 'tack' the flapper valve shut or not?
Just KEENO's weekend fun!
How was your weekend Matt S?
