Just a bit of correction/clarification... . it's not the "extra couple psi" boost that is the issue (within reason) so much as the drive pressure rise. .
Going from 30psi to 32psi is not a major problem (generally) but the "backing up" of exhaust gases trying to get INTO the inlet of that 12cm, 14cm etc IS...
At some point the volume of gases is greater than the exhaust housings' ability to accomodate it. . that is were drive pressure increases to higher levels. . basically it's the "ugly sister" of boost pressure and works against you... alot. .
I bet DF can attest to that one...
The stock H1 turbo is reaching it's upper map at around 26-28psi... the HX35 series is very close to the same, say, 28-30psi, hybrids extend that upward even further... .
No matter what turbo you use, you can run into the same problem.
You can have an exhaust housing too small for the gas volume and have drive pressure issue's.
The wastegate helps to reduce or eliminate that problem by dumping boost or exhaust gas in advance of reaching that drive pressure level. If you run up into and/or over the "map" with no wastegate, then you are going to have high drive pressures AND possibly "over boost condition" as well.
Pastor Bob... aka: BushWakr
