Engine/Transmission (1998.5 - 2002) Wastegate options?
2nd Gen Non-Engine/Transmission What to look for.
Engine/Transmission (1994 - 1998) Mods with mileage?
I just got a dodgezilla hybrid in the mail today :D
I planned to use my existing 12cm housing. Problem is, my existing turbo has a wastegate actuator mounted to the compressor housing. The dz compressor housing doesn't have any way for me to mount my actuator. :(
Aside from springing for another exh. housing, what other options have you guys used? I don't want to run a 12cm dz w/o a functioning wastegate.
I thought about some type of spring, just concerned it my not do the job and may not be reliable enough.
I'll give city diesel a call tomorrow and see what they say, just thought I'd put it out here and maybe get a few ideas.
Thanks in advance
jeff
Sorry, I don't have an answer to your questions, but I went w/ a 14cm housing on my '02 and it is sweet. I have a Piers Hybrid 35 and it really works good.
Let us know what you find out.
Wiredawg
you can make a bracket that bolts to the compressor hold down bolts. then bolt the actuator to the bracket. I have had to do that on turbos on my car. works fine. pretty easy to do also. probably the easiest and cheapest route for you.
