Engine/Transmission (1994 - 1998) Wastegate question
Engine/Transmission (1994 - 1998) HELP!! with GSK
Is there a difference between the wastegate setup between a manual and auto for the HX35w? If so, can I still install a boost elbow on a manual. Mine looks different than some of the pics I have seen.
1998 12V 215 manual transmission.
With your year they are very close to the same your's has a slightly higher psi setting. Yes you can use a fitting on yours.
Bob
