Hey Guys,
I have a question about the turbo wastegate on my truck. I have a 2004 Dodge Ram Cummins 4x4 Automatic. Under normal driving keeping the turbo boots under 15psi the wastegate acts fine. But if you have the psi above 15 or so everythime it shifts it blows the wastegate open and makes a loud noise. It got worse after I install my ATS Transmission in it. I installed the Banks Big Head Wastegate to see if that would help, it did but I still can get it to blow around 18psi and above. And IF you hold it to the floor and let it shift though the gears it doesnt do it at all.
Has anyone ever had this issue? is there any kind of repair?
Thanks for your help!!!!
