Hi all,,
The truck in question is a 96 3500 dually 4X4 automatic,
i have suddenly lost power under boost condition,,if i drive in low boost,,,say 10 and under and accelarate slowly it goes fine. . same if i acclerate in 1'st and 2 gear... then in drive it starts to loose accellaration,,in OD it hardly accelarates at all,,very slowly,,,the fuel filter is only about 5 tanks old,,,but i'll change it just to be sure it's not fuel related,,,the turbo is original to the truck,,and i believe the wastegate may be seized,,,i use the truck daily so i would have thought that would be enough to keep it from seizing,,,but i would like to look at all the possibilities,,,so if anyone can give me some tips on how to test,,,remove,,or free up the waste gate i would sure appreciate it... if someone can tell me if i can do this without removing the turbo itself that would be great. . also,,i remember reading years ago about a wastegate repair kit that was available,,a few members on here had used them with succes... thanks for any help.
