Wastegate/Smarty question.
Loud pop while driving at 65 mph
Injectors
C.Solomon
I have a POD Smarty with the latest update. Previously when I ran level 9 I could see 35-36 lbs of boost at peak level. I have been running my Smarty on lvl 3 for about 2 weeks, yesterday I loaded lvl 9 and now my boost will hit 29 or so and drop to 25. I have the wastegate turned off in the Smarty settings.
Is my wastegate stuck on the "on" position?
previously with the Smarty I could turn it off or on and it worked great.
any ideas?
truck now has 102,xxx miles on it.
Yep, now thw WG control is broke. Get a boost fooler and call it good. ;)
You might be able to get it to enable by reloading a level again but its hit or miss. Either get a boost fooler or WG fooler and boost elbow so that annoying electronic control is no longer, well, annoying. :-laf
Quad seems to sell the most. There are a couple others out there. Check one of the popular diesel retailers for choices.
Yes, the boost fooler is just voltage clamp on the MAP sensor. The WG fooler is just a resistor.
