Water Heater Woes !
BEST Dealer Revenge
BBQ Meat is on!!
Got up today to learn the Bathroom water heater was out. We have another for the Laundry room. Lit it and it went out a little later. Saw the thermocouple was cracked a little, so drove 15 miles round trip, spent $8 and returned. Installed that puppy and it would not light. Wife then advised the other water heater was off. Checked the propane tank and had 50%. Lit the other heater and it went out 5 minutes later. Checked to see if the Fireplace starter worked and, You Guessed It, No Propane. The guage was stuck at 50%. Tapped it and it went to Zero. Filled it and everything works. What a day. :rolleyes: :rolleyes: :rolleyes:
Know the feelin'
Sounds like my shallow well pump in the basement . About a week ago , the wife said "are we out of water" , so I went down stairs and the guage said 25 psi. , but after a little tap , it said 0.
I kinda felt like Homer Simpson , DOOOOOTTTHHHH.
My water heater in the 5er will work on propane but will not work when I switch to electric. It will throw the breaker so must be a short somewhere. Reckon it must be in the air or something.
Water Heater Blunders
When I bought our 5vr. All I did was make sure the propane was on and hit the switch in the trailer. It worked!:cool: This is our second camper.
Two years later, my father-in-law added an electric element to his motorhome's water heater. That's when I decided to get one also. Well like I said earlier, All I did was hit the gas and hit the switch, never looked back. Come to find out my w/h already has a electic element, but the switch is right inside the door of the w/h. Turned it on and works like a charm. If no electictiy, then gas kicks in.
Okie maybe you have a switch inside the w/h door.
Since the topic here contains propane tanks and 5er's, lets expand it a little please. Our 5er is a 1979 Excel with the old style tanks. Instead of having to buy new tanks because of the new law, can I just replace the valve???
Rick
Okie, check your elements in that heater , sometimes when your water heater comes in contact with "hard water" lime will build up and short out the element itself . If this is the case , you can probobly take out the element , and bend up a coat hanger to rake out the lime . Just a possibility.
RHARVEY, as far as I know you can't just replace the valve, it requires a whole new tank:( Sorry, but a buddy of mine at work has to replace both of his this year also.
Rharvey, It is my understanding you can have a propane outfit replace the valves to the new ones. Do not know what the cost would be compared to new purchase.
