OK... its my own dern fault... I put a locking gas cap on my 45 gal. , diamond plate, in-the-bed Aux tank, and it has leaked a little bit of water into the tank.
I check the tank with a flashlight each time I fill up and this is the first time i have ever found water in it. There is not a lot of water, just lots of little "bubbles" on the bottom of the tank... since they could not possibly be bubbles, they must be water!
OK... How do I get rid of the water. I'm not worried about it getting sucked into the system, as I have a larger than stock, fuel filter/water separator mounted in the pumping system, and also have the stock filter, which gets changed faithfully. But I am worried a little about biological thingys growing in there.
The pickup tube on the Aux tank is located about a half inch up, off the bottom of the tank, so they probably won't get sucked into the tube.
How the heck do I get the water out?
