I just bought my second '95 2500, and to my surprise, I saw a "Water in fuel" warning light for the first time (on start up). My first truck never had the light since I bought it last Feb. (my first diesel). (I know, dumb. But I never read the book 'till I have to). . Anyhow, in looking thru "The Dodge manual" the only check of the light involves removing the whole instrument panel, etc. Trying to avoid that just to see if it's just the bulb or not. . There's got to be a way to put some voltage or a jumper or something at the connector under the hood, but I'll be darned if anyone thought to put it in "The Manual". . (I did find the connector disconnected, but re-connecting it made no dif). AND just had the fuel filter changed and the dummies didn't say anything about the connector, or the wif sensor, or check to see if the light was working. Any help out there?
Second topic. . After buying this 2nd truck, I find (driving it home from Ariz. ) that it's a S*** load faster and accelerates better at high speeds than the first truck. I had been convinced that the first truck had the 4. 10 rear end and I know this one has the 3. 54, so that made sense, but in looking again, it seems that the frist one also has the 3. 54. ?? So why the dif in performance? Thay are both stock (except the 2nd truck has an exhaust brake). Please remember that I'm still a bit of a novice, but thanks in advance for any suggestions. . JohnG
