Got some bad fuel a few weeks ago . I can see water on the bottom of the tank in the bed. Fuel filters plug up quicker than normal. I assume I have water in the truck tank also as the fuel goes from the in bed tank to the truck tank via a transfer pump. I was thinking about pumping the fuel out of both tanks . I can get all the fuel out of the in bed tank and I can get what will come out from the truck tank buy pumping it out with the lift pump (Im doing a relocation kit on it anyway) my question is would there be any harm in running 2 gallons of alcohol through the truck tank after pumping it empty as much as possible with the lift pump then pumping out the alcohol. There would be some left in the tank . If I was to fill the tank with 15 gals of diesel would the small amount of remaining alcohol cause any problems? Thanks Otis
