Tried a search and came up w/ nothing. The manual says to drain the water from the fuel at each fill up. This may be a dumb question, but when you do drain the water on the 3rd gen filter... how can you tell if water is coming out or if diesel is coming out?... . everything looks the same color inside the hose connected to the drain valve. Do you go by smell or what? Little help please.
Thanks
Thanks
