Water / methanol injection , and nitrous both have advantages , and have a place in diesel power
1st nitrous is one of the best power adders around , if you follow certain parameters. Nitrous is over 100 degrees below zero when it comes out of the nozzle. the theory of latent heat of vaporization is part of the power gain. This is basically when Nitrous is injected in to the intake track , it boils at over minus 100 degrees, it absorbs the heat and makes the intake air charge denser. This is the reason most maximum effort diesels don’t run a intercooler . Secondly Nitrous chemical composition is 37% oxygen when it reaches combustion temperature in the combustion chamber it separates in to oxygen and nitrogen. The extra oxygen combines with fuel and makes power. You can put all the nitrous in the motor you want , and it will only make power if the fuel is available to combine with it . one of the dangers is if you out run your turbo’s capacity to bypass extra exhaust gasses through the wastegate , you can over speed your turbo’s wheel, and catastrophic turbo and engine damage will result. For small amount of nitrous you will be fire , some of the new progressive NX variable controllers combined with a good hobb’s switch will make for a smooth strong system.
One thing you will run in to in nitrous is if you bring on the system to soon or too low a boost , it will put out the fire in the diesel , by making the intake temp too cold to run. This will be a little scary , as the engine will go dead , or some times bark back, just raise the hobb’s switch level a little.
Water / Methanol this is used to make power in a different way , the water will act as a cooling effect in the intake charge and will give it a kick on expansion in the combustion chamber , but if best effect is to aid in lowering EGT’s the methanol is use in a different way. First methanol is a fuel , but that is not its biggest power generation ability , its is the fact that it speeds up flame front propagation , this has the effect of fooling the motor in to believing it has more timing . this is most advantageous on fixed timing trucks IE
P-Pump Cummins this too works good with NX new progressive controller
