Water Leak Inside Cab
I want to add a factory break controller.
Air suspension TSB
I'm unable to locate a leak anywhere. I've noticed recently after a rain that the inside of the cab windows become heavy with dew as if the humidity inside is very high. A couple of times I've found droplets of water on the metal liner/skirting just inside the drivers side front and back doors at floor level. The windows are closed tightly and I've found no wet carpet areas. About a year ago, the dealer replaced the clearance light/covers on some sort of recall. Any ideas where to look?
If you sure it is up front it is most likely the clearance lights. If it is in the back it is the third brake light.
Thanks. I'll take off the 3rd brake/cab/camera mount tomorrow. The only place I'm seeing any water is very heavy dew, to the point of dripping down on all the windows as if the humidity/dew point is high inside vs outside. Just a bit on the metal interior floor panel skid plates where the door bottom addresses the floor. I checked the drains in the sunroof first and the rear slider is closed also. Found no wetness or water on the floor behind the rear seat.
