Wiredawg
Fellow Rammers:
I've had problems w/ water leaks coming in on both kick panels: the frsh air inlet in driver's side and the fresh air inlet going into the HVAC on the passenger side. Everytime it rains or I wash it, water leaks in. I thought I had the driver's side whooped today when I removed the drivers kick panel, which is a major pain to get off with two of the screws only being able to be removed w/ an offset phillips screwdriver at a quarter turn at a time. Anyway, I replaced the rotten foam gasket with new camper shell gasket, put it all back together and still it leaks. While I had it apart, there is a major water flow coming from the sides of the the front grills under the wind shield wipers.
I'm getting ready to remove it again and am considering two attacks: divert water draining from the top and maybe double the gasket.
Has anyone else had this problem? I appreciate any suggestions.
Thanks, Wiredawg
Thanks, Wiredawg
