CoastyAV8R said:We used water methanol in one of our older aircraft (Gulfstream 1) and the water/meth is EXTREMELY corrosive. I'm not sure how the Cummins motor would handle it but the plane made 20% more power when we used it but the duration of use was limited to less than a minute because of temps. If any water/meth was spilled while the aircraft was serviced, it was treated like an emergency getting it cleaned up as it would strip paint, remove grease and on bare metal surfaces cause severe etch type corrosion. I would think there would be better ways to make power than using water/meth having seen how much of a pain in the rear it is just to handle the stuff...
jelag said:water is a normal by product of combustion... remember on the older cars and trucks the exhaust system used to rust out before the use of stainless steel... the combustion process would leave moisture, water vapor in the exhaust and rust it out... .
Jim
Sarge said:WPeschel, I just saw your sig. Sorry for your loss. Folks like us share a common bond. Be safe brother... ... ... Sarge[/QUOT
Thanks Sarge you be safe too...
hasselbach said:water and methanol will not remove paint. I spill it on my race car all the time and it does nothing to the paint.
windshield fluid is water-alcohol mix, big difference.
Caveman said:Methanol is Methyl Alcohol brainiac![]()
CoastyAV8R said:I'm curious if the kit Snow industries sells uses a different type of water/meth than what aircraft use? I know the stuff we use isn't windshield washer fluid, the guys have to wear a splash shield, rubber apron and rubber gloves to service the aircraft.
hasselbach said:Be careful not to confuse ALCOHOL or ETHANOL with METHANOL! .
hasselbach said:Brainiac wishes to teach you:
1. Methanol (methyl alcohol) is produced from the distillation of wood and is a clear, colorless, volatile liquid with a weak odor that is somewhat sweeter than ethanol and alcohol.
Alcohol and Ethanol is a renewable energy fuel fuel made from sugar crops, such as sugar cane and corn. Methanol, on the other hand is made from fossil fuels such as coal and natural gas.
