Water meth injection
Will my 2003 be ok with just a new shortblock?
High Idler
Well i did it. I put on the water injection from Snow performance. And i must say it works pretty good. I am just usiing WWF right now but when the injection comes on, my pyro is about 125-150 cooler than normal and i can feel a difference in power as well. I am going to try a 75% meth and water mix today and se how that feels. The system installed easier than i thought and any questions i had, Matt was more than happy to answer. I will keep you posted as to the new results with more meth. https://www.turbodieselregister.com/forums/newthread.php?do=newthread&f=127#
I chose to use the windshield washer bottle for two reason's. the first is that it was hard to find a location to mount the provided resovoir( i am sure there is one but i am a bit lazy when it comes to install). And the second was the location of the WWF bottle makes it easy for hook up and when you are running low on fluid the low fluid indicator comes on on the dash. It doesn't use alot when you are using it so the factory wwf bottle is good enough.
Windshield washer tank is real nice to use, just 2 days ago I was making a test run and after it I heard the Ding..... she was low on water, kind of makes it knuckle head proof as I'm sure I would run the tank dry without it... ... . not good on pumps.
Jim
