Water Meth install question??
HT3B compound
03 3500 4x4 Six Speed PROBLEMS!!! Need HELP ASAP!
I just purchased a stage 3 snow performance water meth kit to go along with the mods listed below. :D What Im wondering is, can I use the same EGT probe that my edge box is running off or do I need to drill another one just solely for the water meth? Anyone try this? comments? Thanks again.
I have a older system with a cooling mist controller. I do not use a EGT probe at all for injection, I use boost. However you must use a stand alone probe. You might short the electronics out with extra wiring.
Rick
I am using the the same thermo-couple for my mech gauge and banks PDS. They are working fine and mach the 2nd thermo-couple I an using with the quad commander. I don't think there would be a problem with you using the same probe.
